HIPAA-compliant fax service for Epic EHR
Improve productivity, ensure PHI data security, and accelerate communications for patient referrals, lab results, and more with secure, reliable fax technology.
Accelerate communications and boost productivity with access to all the content you need, right from within Epic.
Healthcare is a fast-paced industry, and healthcare providers work with a ton of documents and communications each day to ensure patients are getting the care and services they need quickly. AccuRoute is configured to operate seamlessly with Epic 2017+, so you can quickly and easily get your fax service up and running with no downtime and provide your busy staff with a reliable secure way to access everything they need right from the Epic dashboard.
AccuRoute works seamlessly with Epic 2017+. Quickly and easily set up an account, transfer any existing fax numbers, and contact your Epic representative to begin faxing immediately with no service downtime.
Download the datasheet
Solution benefits
- Send faxes, verify delivery, access detailed records, utilize Epic data fields for enhanced reporting, and more all from your Epic dashboard
- Streamline time-sensitive patient communications while meeting compliance standards like HIPAA, PHIPA, and PCI DSS
- Empower your staff by allowing them to manage patient communications and access detailed transmission records right from within Epic
- Create reports on fax usage by patient, sender, recipient, or customized fields to ensure compliance
- Reduce risk by using a highly-scalable, reliable infrastructure that seamlessly supports a wide range of geographically dispersed locations
Manage work faster and smarter
- Accelerate communications and data exchange by allowing users to send or receive faxes and access PHI from one place
- Send faxes directly from the Epic interface for everything from patient referrals, to physicians’ notes, prescriptions, lab results, and more
- Automatically deliver inbound faxes to specific network folders and attach them to the right patient record
Access content quickly and securely
- Get the content you need and ensure HIPAA, PHIPA, and PCI DSS compliance, all in one step
- Access detailed records of every fax transmitted or received via the AccuRoute web portal
Transform Your Data Workflows with Cutting-Edge AI
Elevate Efficiency and Accuracy with Our Cloud Data Extraction Solution
Transform Data Management with AI-Driven Cloud Solutions
Enhance Efficiency, Accuracy, and Global Communication
OL Connect Desktop Features
Discover OL Connect Desktop’s robust personalization and modern print production features that enable your business to enhance customer communications.
